Forerunner 255 Series Battery Life Assumptions
The battery life of your Forerunner® 255, Forerunner® 255 Music, Forerunner® 255S, and Forerunner® 255S Music watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below may result in reduced battery life. The information presented below is a reference-only guide for general use of the Forerunner 255 products.
Forerunner 255 | Forerunner 255 Music Smartwatch - Default Display Configuration
Notifications per Day90
Number of Interactions per Day160
Device-Generated Alerts per Day (Move or Goal Alerts)2
Hours per Day Outside of Bluetooth Range of Phone1
Display Brightness & TimeoutDefault Settings
Watch Face1Default
Number of Gestures per Day200
Pulse Ox ModeDisabled by Default
Number of Minutes of Music Streaming0
Number of Timed Activities0
Battery LifeUp to 14 days
Forerunner 255 | Forerunner 255 Music - Activity Mode
Number of Interactions per Hour10
Minutes of Interaction Post-Activity1
Number of Gestures per Hour8
Assumed Temperature Range for Battery Life Specifications10C – 40C
GPS-Only Mode without Music Battery LifeUp to 30 hours
All Systems (Default) Mode without Music Battery LifeUp to 25 hours
All Systems + Multi-Band Mode without Music Battery LifeUp to 16 hours
GPS-Only Mode with Music Battery Life (255 Music Only)Up to 7 hours
All Systems (Default) Mode with Music Battery Life (255 Music Only)Up to 6.5 hours
All Systems + Multi-Band Mode with Music Battery Life (255 Music Only)Up to 6 hours
UltraTrac Mode without Music Battery LifeUp to 54 hours
Forerunner 255S | Forerunner 255S Music Smartwatch - Default Display Configuration
Watch Face1Default
Battery LifeUp to 12 days
Forerunner 255S | Forerunner 255S Music - Activity Mode
GPS-Only Mode without Music Battery LifeUp to 26 hours
All Systems (Default) Mode without Music Battery LifeUp to 20 hours
All Systems + Multi-Band Mode without Music Battery LifeUp to 13 hours
GPS-Only Mode with Music Battery Life (255S Music Only)Up to 6 hours
All Systems (Default) Mode with Music Battery Life (255S Music Only)Up to 5.5 hours
All Systems + Multi-Band Mode with Music Battery Life (255S Music Only)Up to 5 hours
UltraTrac Mode without Music Battery LifeUp to 44 hours
1 The “default” watch face is the watch face present on the device when it is taken out of the box. The Forerunner 255 products are designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
Sumber terkait
