GroupRide offers users access to a shared course, group messaging, and live location data on group members using a special code. Below are top FAQs related to the feature. Select a topic from the following list to jump to it.
What Compatible Edge Cycling Computers Work With GroupRide?
GroupRide requires the software version on your Edge to be up to date. If you do not see this feature on your device, update your software.
Edge® 540 | Edge® 540 Solar
Edge® 840 | Edge® 840 Solar
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
- Edge® Explore 2
Back to Top
What Are the Requirements to Use the Feature?
Back to Top
How Do I Create a GroupRide?
Locate the GroupRide:
From the menu, select
Select Safety & Tracking.
Select GroupRide.
From your widget glance.
Grant Consent for GroupRide:
Back to Top
How Do I Share a GroupRide?
Sharing a GroupRide Code
Once a GroupRide is created, there will be a code which can be shared. Users can either use the code manually or it can be shared through the device via the Garmin Connect app.
Locate the GroupRide menu.
In Glances
In the Menu
Select
Select Safety and Tracking.
Select GroupRide.
Select the GroupRide to be shared.
On the GroupRide's summary page, select
(top right).
Select Share Code.
A prompt will appear on the Garmin Connect app.
Select View Code.
Select Share.
Sharing During a GroupRide
Once in the ride, both the code and the option to share in Garmin Connect app can be accessed.
On touchscreen Edges, select the top right share icon on the GroupRide data screen, or on any screen tap the screen to show and select the overlay.
On button-based Edges, the code is visible in the GroupRide data screen and the option to share the code is available in the context menu.
Back to Top
How Do I Start a GroupRide?
NOTE: When you start a GroupRide with a course, the course will be saved on the Edge.
In Glances
In the Menu
Select
Select GroupRide.
Select Enter Code.
Select Start Location Sharing.
Back
to Top
Using the GroupRide Data Screen
While in a GroupRide, there will be a new data screen available showing messages and the rider list. The screen can be enabled or disabled in the activity profile settings. Refer to your owner's manual for customizing data screens for your Edge model.
NOTE: The Edge 540 Series will only offer messaging on this data screen. The rider list can be accessed in the GroupRide context menu by selecting the enter button.
Messaging
Your message will be visible to anyone who joins the GroupRide. On touchscreen Edges, tap the arrow or on the 540 series, hold the enter key to send a message. A list of predefined messages can be customized in the Garmin Connect App. If you are not currently on the GroupRide data screen, a notification will appear on the Edge screen. The messages can be dismissed, replied to, or muted.
Rider List
The rider list will show details for the 25 closest riders within 25 miles, which is refreshed every 15 seconds. If there are additional riders more than 25 miles away, there will be a "Show More" option with a simplified list of all group riders. The simplified list does not automatically refresh, it must be manually refreshed with the sync icon in the upper right.
Selecting any rider on the list will show their position on the map and follow their ride. This screen will follow the selected rider.
Back to Top
Map Legend
During a GroupRide, your Map Data Screen will show the closest 25 riders and refresh every 15 seconds. Riders on the map are recognized by icon color and shape:
Back to Top
Map Options
Options to customize the map are located in the GroupRide menu's 3-dot icon.
Back to Top
Can I Use GroupRide and LiveTrack at the Same Time?
Yes. LiveTrack and GroupRide will work at the same time. If location sharing for either LiveTrack or GroupRide is active, the eye icon will be in the status bar. When using GroupRide, there will also be a banner on the timer overlay.
Back to Top
How Do I Leave A Group Ride?
The Edge will automatically leave the GroupRide when you save your activity.
To Leave the GroupRide At Any Time:
NOTE: Leaving the GroupRide requires cellular data connection.
From the GroupRide Menu:
From the Edge home screen, select
Select GroupRide.
Select the current GroupRide.
Select Leave GroupRide.
From the Controls Widget on Touchscreen Edges
From any screen, swipe down to view widgets.
Scroll to the Controls Widget.
From the Context Menu on Edge 540 or 840 Series
From the GroupRide Data Screen, Select the enter button to show the context menu.
Back to Top
How Does This Feature Differ from Garmin Connect GroupTrack?
GroupTrack provides live location information only and does not offer interactive features like GroupRide. GroupTrack is also available on more Garmin devices. For more details see: Garmin Connect App GroupTrack Feature
Back to Top
