Red | Green | Orange | |
Watch Face |
Using Red Shift Mode on an AMOLED Display Watch
The bright AMOLED displays on Garmin® watches come with a mode called Red Shift. More than just a different color for a watch face, Red Shift changes the entire watch interface to shades of red, green, or orange. This can help preserve your night vision by blocking the colors of light that constrict pupils, and also reduce sleep cycle disturbances. You can use every feature of the watch while in Red Shift mode, including activities and the map, but it can reduce visible contrast on some screens. Red Shift can be enabled from the controls menu on the watch, through a hot key (if compatible), or the display settings.
Enabling Red Shift
NOTE: Not all watches compatible with Red Shift will have all of the following options. To determine compatibility and for steps to access these options on your specific watch, refer to your owner's manual.
From the Controls Menu
To enable Red Shift, access the Controls menu. Select the eclipse icon to turn on Red Shift. To disable Red Shift, select the icon from the Controls menu again. If you do not see the Red Shift icon, you may need to add it to your Controls menu.
Using a Hot Key
With a compatible watch, you can enable Red Shift through a hot key shortcut on your watch. Holding the designated button or button combination will switch the watch to Red Shift mode. Holding that button or button combination again will switch back to normal display mode.
Display Settings
The following instructions are generic and may not exactly match your specific watch model. For instructions for your watch, see your owner's manual.
Access your Settings menu.
Select System.
Select Display.
Select an option:
During Activity
General Use
During Sleep
Select Red Shift.
Select an option:
Status
NOTE: Red Shift for During Sleep is only an On/Off toggle.
Off
On
After Sunset
Color
Red
Green
Orange
With this enabled During Sleep, the watch will turn on Red Shift during your scheduled sleep times, and it will switch back to normal display settings after your scheduled time ends.
Examples of Red Shift
Map Screen |
