Editing AutoShot Information on the Garmin Connect Website
The Garmin Connect™ website allows you to edit the shot location, edit the club used, remove shots, and add shots with the AutoShot feature.
When reviewing and editing shots, the type of shot is indicated by the colored dot with the yardage next to it.
  • Blue - Approach Shot
  • White - Drive Shot
  • Yellow - Tee Shot
Editing Shots
This allows you to edit the club used, mark a shot out of bounds, or delete the shot.
  1. From the Dashboard, hover the mouse to left side of the page to open the menu.
  2. Select Golf.
  3. Select Scorecards.
  4. Select the scorecard with a shot you wish to edit.
  5. Select the score for the hole you want to edit.
  6. Select Edit/Add Shots.
  7. Select Three Vertical Dotsnext to the shot you want to edit.
  8. Select an option:
    • Edit Club
    • Mark Shot Out of Bounds (OB)
    • Delete Shot
  9. Select a club if Edit Club was chosen.
  10. Select Save.
Adding Shots
This can be useful if a shot was not detected by your device during the round.
  2. Select Golf.
  4. Select the scorecard you want to add the shot on.
  5. Select the score for the hole you want to add the shot on.
  7. Click on the location of the hole map that you want to add the shot.
    NOTE: The shot will automatically be ordered on the list of shots with the placement on the map.
  8. Click and hold Six Dots Icon For Dragging Item With Mouse next to shot in the list and drag it to the correct place in order if needed.
  9. Select Save.
See Related for more information on the AutoShot feature.
Sumber terkait
