GNX 375 with System ID: A31003D31B618, A3100FFFFFFFF, A31005D60BE1D, or A31006399B2A5
GNX 375 Shows a System ID of A31003D31B618, A3100FFFFFFFF, A31005D60BE1D, A31006399B2A5:
  • A GNX 375™ IFR navigator with a system ID of any of these indicates that your configuration module has failed or is not installed correctly.
What is a System ID?
  • The system ID is generated by a configuration module that is part of the backplate. The system ID is a unique number that is not repeated in other aircraft.
How to Find Your System ID:
  • The system ID can only be found while sitting inside the aircraft.
  • On the GNX 375:
    1. Select System
    2. System Status
    3. The system ID will be listed at the top of the page.
Solutions
  • Certified Aircraft:
    • You will need to visit a Garmin Aviation Dealer so that they can investigate your GNX 375's configuration module and generate a new system ID. Location of a Garmin Dealer near you.
  • Experimental Aircraft:
    • Visit a Garmin Aviation Dealer to investigate your GNX 375's configuration module, or contact Garmin Aviation for support.
Sumber terkait
