Differences Between Maps on Preloaded Cards and Downloadable Content
Maps for Garmin devices are sold as pre-programmed data cards or as direct downloads.
Important Items to Note When Choosing a Purchase Option
  • Review the Requirements tab and Compatible devices tab on the specific map product page to ensure your device will work with the selected map and format.
  • Not all formats are available with all map offerings. The available formats for the specific map product will be listed under Format on the map product page.
  • For both pre-programmed data cards and Downloadable Content (DLC), the map cannot be updated. If you wish to have updated map content, a new map must be purchased.
    • TopoActive and City Navigator® maps that come already installed on select Garmin devices can be updated using Garmin Express™ software.
Differences Between Pre-Programmed Data Cards and Downloadable Content
Pre-Programmed Data CardsDownloadable Content (DLC)
  • The recommended method to purchase and use additional maps.
  • Ready for immediate use, no setup required.
  • The card can be moved between compatible Garmin devices.
  • Cannot be removed, transferred, or combined with other pre-programmed data cards or internal memory of a device.
  • The order takes an additional 1 to 3 business days to process before shipping.
  • Must be downloaded using Garmin Express program and a high-speed internet connection.
  • Can be downloaded immediately after purchase.
  • May be downloaded to the device, or to your own SD card if the device has insufficient space.
    • The required size of the SD card may vary depending on the size of the DLC map and on the device's card requirements.
    • For more information, see Related below.
  • The map may only be used with one Garmin device and cannot be transferred between devices, even if installed on an SD card.
Sumber terkait
