Viewing Speed With the inReach Mini 2
The inReach Mini 2 features a compass that will show your heading and, with up-to-date software, your speed. The Garmin Explore app can also be used to display your speed by enabling data fields on the map page.
Viewing Speed on the inReach Mini 2
Ensure that the software on the inReach Mini 2 is up to date.
For details, see - Updating the Software on Your inReach Mini 2.
From the home page, press
or
to scroll through the widget glances.
Use the OK button to select NAVIGATION.
Press
to scroll down to the compass page.
Speed will be displayed at the bottom of the screen.
Displaying Speed in the Garmin Explore App
Open the Garmin Explore app.
Select
Map.
Select
Select
, then select Map Settings.
Touch Data Fields to toggle it on.
If the toggle is set to
, the item is visible on the map.
With Data Fields enabled, your heading, elevation, and speed will be displayed at the bottom of the map page.
