The Buttons on My Garmin Watch Do Not Respond When Pressed or Appear to Be Stuck
If a button on your watch stops working, it is possible that debris may be present between the button and the watch housing. As a first step to resolving this issue, thoroughly rinse your watch with fresh water.
I Rinsed My Watch but the Button Is Still Stuck
Stuck buttons after rinsing the watch may require you to follow the steps below to restore functionality.
  1. Fill a small bowl with fresh water.
  2. Place the watch in the bowl and allow to soak for 10 minutes.
  3. Remove the watch from the bowl and rinse thoroughly under a low-pressure faucet.
  4. Shake off the excess water and allow it to air dry completely.
For more information on cleaning a Garmin device, refer to the Device Care section of your owner's manual.
IMPORTANT: To avoid causing permanent damage to your device, follow the guidelines below.
  • Avoid extreme shock and harsh treatment, because it can degrade the life of the watch.
  • Do not use any sharp objects to clean the watch.
  • Avoid chemical cleaners and solvents that can damage plastic components and finishes.
Sumber terkait
