Updating the Firmware and Syncing Account Information to an inReach Mini
The inReach® Mini satellite communicator receives updates from two different computer programs - the Garmin Express™ program and the inReach Sync program. We highly recommend following the instructions to run both Garmin Express and inReach Sync for the best experience with your inReach Mini. See the instructions below for both programs.
Garmin Express
Garmin Express applies firmware updates to the inReach Mini, but it will not sync any account changes such as subscription plan changes, updated Contacts, QuickText, or Check-in Messages ( formerly known as Preset Messages). To sync account information, see inReach Sync below.
Updating Firmware with Garmin Express
  1. You need Garmin Express software installed on your computer first. If you already have the Garmin Express program installed, skip this step.
    Download for Windows button  Download Mac Button
  2. Connect your inReach Mini to the computer with a Micro USB Data cable.
    Micro USB Cable inReach Mini USB Port
  3. The Garmin Express program will be launched during the installation process. If you already had it installed, launch the Garmin Express program.
    Garmin Express Desktop Icon
    Windows: Either double-click the Garmin Express icon in the system tray (next to your time), double-click the shortcut on the desktop, or search for Garmin Express in your Start menu.
    Mac: Garmin Express can be found in the Applications folder in Finder.
  4. Select the inReach Mini, or click Add a Device and follow the on-screen prompts if your inReach Mini is not listed.
    Add a Device in Garmin Express
  5. Garmin Express will display the available updates. Click Install or Install All to install all of the updates.
    Update Available Screen
  6. Review the Terms and Conditions and click Accept to proceed.
    Terms and Conditions Screen
  7. Review the important notes before continuing to ensure the software update installs smoothly. Click Continue.
    Important Notes Before Continuing
  8. Once the update starts, Garmin Express will display the current progress.
    TIP: Hover your mouse cursor over the progress bar for detailed progress information.
    Software Update Progress
  9. You will see a You're up to date! message when the update is finished.
    You are Up To Date Confirmation of Updates Completed
  10. Disconnect your inReach Mini from the computer and power it on. You will see Applying Update on the inReach Mini, then it will return to the home screen once complete.
inReach Sync
inReach Sync and the Earthmate® app cannot send firmware updates to your inReach Mini. To install firmware updates, see Garmin Express above.
After adding or editing Contacts, QuickText, or Check-in Messages ( formerly known as Preset Messages) on your Garmin Explore account, it is important to use inReach Sync to ensure your information is updated directly to the inReach Mini through a wired connection.
NOTE: For issues syncing, see -  Troubleshooting inReach Sync for the inReach Mini
inReach Sync for Windows
null
Installing inReach Sync for Windows
  1. Log in at the Garmin Explore website.
    Sign In for Explore Website
  2. Select Plans & Devices.
  3. Select Sync & Update.
    Sync and Update
  4. Select Windows or Mac to start the download.
    Windows or Mac link
  5. Locate the download on your computer and open it:
    Google Chrome Instructions
    1. If prompted, choose where you want to save the file, then click Save.
    2. When the download finishes, you will see it at the bottom of your Chrome window. Click the file name to open it.
      inReach Sync Download in Google Chrome
    Mozilla Firefox Instructions
    1. When prompted, click Save File.
      Save inReach Sync Download in Firefox
    2. When the download finishes, the down arrow on your toolbar will appear blue Blue Down Arrow. Click the down arrow, then click the file name to open it.
      Open inReach Sync From Firefox Downloads
    Microsoft Edge Instructions
    When the downloaded finishes, it should display under the down arrow on your toolbar. Click the file name to open it.
    NOTE: If you do not see this, select ••• in the top right, then Downloads.
    Open inReach Sync from Microsoft Edge Downloads
  6. Follow onscreen prompts to complete installation.
Using inReach Sync for Windows
  1. Plug the inReach Mini into the computer.
  2. Launch inReach Sync from the computer (see Opening inReach Sync on a Windows or Mac Computer).
    inReach Sync icon
    TIP: Log in if requested. Use the same email and password the device is associated with.
  3. inReach Sync will automatically detect your inReach Mini and begin syncing.
    Sync Started
  4. Close inReach Sync when the sync completes.
    Green Check Mark for Sync Complete
inReach Sync for Mac
null
Installing inReach Sync for Mac
    Sync and Update
    Windows or Mac link
    NOTE: On Mac, the file should appear on your desktop
    Safari Instructions
    1. If prompted to allow downloads on explore.garmin.com, click Allow.
    2. Click the down arrow on your toolbar, then double-click the file name to open it.
      Open inReach Sync from Safari Downloads
    1. When prompted to save the file, click OK.
Using inReach Sync for Mac
    inReach Sync icon
    TIP: Login if requested. Use the same email and password the device is associated with.
    Sync Started
Watch Our Videos
Windows
Support: Updating an inReach Mini (PC)
Support: Using inReach Sync with an inReach Mini (PC)
Mac
Support: Updating an inReach Mini (Mac)
Support: Using inReach Sync with an inReach Mini (Mac)
What If My Plan is Suspended?
Only data from the account will sync to an inReach device while suspended.
Data recorded by an inReach device will not sync to the Earthmate app or to the Garmin Explore website. Data recorded during this period will sync once the account has an active subscription.
Sumber terkait
