Acceleration Limiter Setting on a GHP Autopilot
The acceleration limiter setting is a safety feature used by the Course Computer Unit (CCU). If the CCU senses a quick or sudden turn, it will send a signal to stop initiating the turn. This setting limits the aggressiveness of autopilot-controlled turns. You can adjust this within the Dealer Mode setup menu.
Dealer Mode
      1. Press Menu
      2. Select Setup
      3. Select System
      4. Select System Information – Once on the System Information page press and hold the center soft key until Dealer Mode appears
      5. Press the back button 2 times
Acceleration Limiter from a GHC Display
    1. Select Dealer Autopilot Setup
    2. Select AutopilotTuning
    3. Select Acceleration Limiter - select an option
      • The default settings is 66%
      • Increasing this setting will limit the turn rate of the autopilot
      • Deceasing this setting will allow the autopilot to make turns more sharply
Acceleration Limiter from a Compatible Garmin Chartplotter
        • The default setting is 66%
        • Decreasing this setting will allow the autopilot to make turns more sharply
Warning: This setting should be adjusted with care. Any adjustment lower than the default setting of 66% can result in the autopilot making very aggressive turns.
