How to View Marine Map Details on an Outdoor Watch
In order to view Marine mapping you have loaded to your compatible outdoor watch, you will need to enable the Marine Map theme and disable other mapping installed to the watch. Follow the instructions below in order to make sure that your watch is properly set to display marine mapping.
NOTE: TopoActive mapping will have limited Marine data. LakeVü™ and BlueChart® mapping can be purchased for additional coverage see - Wearables Mapping.
Enabling the Marine Map Theme
  1. Hold UP/MENU to enter the Main Menu.
  2. Select Activities & Apps.
  3. Select Map.
  4. Select Map Settings.
  5. Select Map.
  6. Select Map Theme.
  7. Select Marine.
Your theme should now be set to Marine as shown below.
marine map theme enabled
Disabling Other Maps
  3. Select Map.
  5. Select Map.
  6. Select Configure Maps.
  7. Disable non-Marine Maps except for Worldwide DEM Basemap, NR (if listed).
Marine Map Details Shown
What information the map displays is based on your watch's zoom level. Below are examples of what information will display based on the level of zoom.
Fēnix Map 20KMAt a scale of 20km, bodies of water are visible, but no details.
Fēnix Map 12KMAt a scale of 12km, names of bodies of water are visible, but no details.
Fēnix Map 5KMAt a scale of 5km, depth markers start to be visible.
Fēnix Map 3KMAt a scale of 3km, shoreline contours are visible.
fēnix 1.2 kmAt a scale of 1.2km, both depth markers, and shoreline contours are present.
fēnix 800mAt a scale of 800m, the most detailed version of shoreline contours are present.
Sumber terkait
