Are You Ready to Go RV'ing?
See the tips below to get ready to hit the road with your Garmin RV navigator!
Charging Your Device
Garmin recommends you fully charge your device before your travels. This is especially true if your Garmin RV navigator has been put away for the winter.
- The recommended method to charge is to install the device in the mount, and connect the mount to vehicle power.
- Or you can connect the device to an optional power adapter accessory, such as a wall power adapter with at least a 2A output rating.
- You can purchase an approved Garmin® AC-DC adapter from a Garmin dealer or www.garmin.com.
- The device may charge slowly when connected to a third-party adapter.
- Your device should power on and indicate it is receiving a charge.
- If it doesn’t power on, hold the power button for 30 seconds.
- If your Garmin RV navigator does not power on, see the appropriate link below:
- Camper/RV 780, Camper/RV 785 Automotive Device Frozen or Not Powering On
- Camper/RV 795, CamperCam/RVcam 795:
- Camper/RV 890, Camper/RV 895, Camper/RV 1090, and Camper/RV 1095: Automotive Device Frozen or Not Powering On
- A full charge may take several hours.
- You can verify a full charge by unplugging the device and checking the battery icon on the home screen.
Updating Your Device
It is important to update the software and maps to make sure you have the best experience on the road. An update via Wi-Fi is the easiest option to install these updates. You can alternatively use the Garmin Express™ software. For more details choose the desired link below.
See the appropriate link below when using Wi-Fi to update your device.
- Wireless Map and Software Update Instructions for Camper/RV 785.
- Wireless Map and Software Update Instructions for Camper/RV 780, Camper/RV 795, and CamperCam/RVcam 795.
- Wireless Map and Software Update Instructions for Camper/RV 890, Camper/RV 895, Camper/RV 1090, and Camper/RV 1095.
For instructions using the Garmin Express software, see Updating Automotive Maps and Software with Garmin Express.
Updating the Garmin Drive™ App and your Paired Smartphone or Tablet
If you are using the Garmin Drive app with your Garmin RV navigator, the app should be kept up-to-date in order to take advantage of new features, improvements, and bug fixes. Updates are free and easy to install.
- Check for and install updates to the Garmin Drive app through your smartphone or tablet's App Store or Play Store.
- Check for and install any available operating system updates for your paired smartphone or tablet.
- Consult your phone or tablet manufacturer for assistance if needed.
See also:
- Video: Finding, Saving & Deleting Addresses on an Automotive Device
- Video: Garmin Drive™ App Features and Benefits
For additional help search for a solution in the Support Center after entering the product name or serial number of your device.
