Alpha 200, 200 Plus, and 300 Handheld Series Training Key Setup: Adjust Stim Each Use
The Alpha® 200, Alpha 200i, Alpha 200 Plus, Alpha 300, and Alpha 300i dog tracking handhelds have a setting you can toggle on and off related to adjusting stimulation levels when you use a training function.
  • With this toggled on any time you press a training key associated with a stimulation (Momentary or Continuous) a page will drop down letting you know you can adjust the level as needed.
  • With this toggled off any time you press a training key associated with a stimulation (Momentary or Continuous) you will not get a drop down allowing you to adjust the stimulation levels.
Adjust Stim Each Use: ON
  1. Select Dog Training Setup
  2. Select Default Settings
  3. Select Adjust Stim Each Use
  4. Toggle to the On position
Stim Adjust OnStim Adjust Page
Adjust Stim Each Use: OFF
  4. Toggle to the OFF position
Adjust Stim OffAdjust Stim Off Press
Sumber terkait
