How to Search, Save, Edit, or Delete Locations on an Automotive Device
Choose a topic below for instructions on searching for, saving, editing, assigning categories to, or deleting addresses or points of interest (POI).
Detailed Video Walkthroughs can be Found Below:
To Search for an Address
 1. Touch Where To?
2. Touch  to change the city/state or location if necessary
3. Touch Address
4. Follow the on-screen instructions to enter the address information.
The address should appear in the list of search results. Select the desired destination from this list and touch Go.
To Search for a Point of Interest
1. Touch Where To?
2. Touch Categories
3. Select the POI category (food, fuel, lodging, etc.) best matching your desired destination
4. Select a subcategory if necessary
5. Select the destination from the listed nearby POIs
6. Touch Go to calculate a route
It is possible to save a destination so it can be easily accessed in the future. The destination will then be accessible from Favorites or Saved in the Where To? menu on the device.
To Save a Result
1. Search for an address, POI, etc., using the options available in the Where To? menu
2. Select a location from the search results
3. Touch the  info button
  • Skip this step on some devices
4. Touch Save.
  • If a Save button does not appear, the location has already been saved.
5. Enter a name for the location if prompted or touch Done
6. Touch OK when notified the address has been added to Saved Places
Repeat steps to save additional destinations.
To Edit a Saved Location
1. Touch Where To?
2. Touch Favorites or Saved
3. Touch the location you would like to edit
4. Touch the  info button
5. Touch the  menu button
6. Touch Edit
7. Touch the information you would like to change
NOTE: Categories will be replaced with Collections when connected to the Garmin Drive™ App and Garmin Explore™ is enabled for the zūmo® XT GPS navigator. To switch back to Categories, a restore can be performed which will set the zūmo XT back to default settings.  For steps on restoring the settings to default see Restore Settings.
  • You may change the name, phone numbercategories, and map symbol assigned to the location
Touch and hold the back arrow to return to the main menu.
To Assign a Category to a Saved Location
1. Touch Where To?
6. Touch Edit
7. Touch Categories
8. Enter one or more category names, separated by commas.
9. Select done.
NOTE: Categories appear in the saved locations menu after you have saved at least 12 locations.
To Delete a Saved Location
1. Touch Where To?
3. Locate and touch the favorite you would like to delete
  • Some devices require you to touch the Info button (lower-case i) after this step.
4. Touch the menu button (three lines) in the upper-left of the screen
5. Touch Delete
6. Touch Yes
The selected saved location(s) will now be deleted.
To Delete Multiple Saved Locations:
1. Touch Where To?
3. Touch the menu button (three lines) in the upper left corner
4. Touch Delete, Delete Favorites or Delete Saved Places
5. Touch the location(s) you would like to delete
  • Touch Select All if you would like to delete all saved favorites.
6. Touch Delete once the desired locations are selected
7. Touch Yes
Sumber terkait
