How to Stop Chart Installer From Opening All the Time
Some computers may want to open the Chart Installer software any time a USB device or memory card is plugged in. Follow the instructions below to remove the NavService process from startup.
After disabling NavService, the Chart Installer needs to be actively launched using the application icon/shortcut or from your applications menu.
Windows Users
  1. Select Start/Apps button in the lower left corner of your screen
  2. In the search box, type “msconfig”
  3. The System Configuration window will appear
  4. Select Startup tab
  5. Click on Open Task Manager to manage your start up items
  6. Search for NavService entry
  7. Disable it
  8. Select Apply and exit
Mac Users
  1. Open the Finder
  2. Go in Applications
  3. Select Chart Installer folder
  4. Find the file titled NavService
  5. Rename this file
  6. Check on pc for: ./Users/ <user name > /Library/LaunchAgents/org.Navionics.NavService.plist
  7. Remove .plist file
