Exporting Shot Data from the ShotView App
You can export one or more shot data sessions from the ShotView™ app.
To export a single shot session to a .csv (comma separated values file format), with a shot session selected:
  1. In the upper right corner of the app select the 3 green dots
  2. Select Export as CSV
  3. You will see the file name of the .csv file to be exported
  4. Select where you want to export the data
    • For example you can choose to email the file to yourself or someone else as an attachment
  5. If you have added additional information, for example Cold Bore, Clean Bore, or Notes, that information will be contained in your export as well
To export multiple shot sessions together to an .xls (Excel file format), with the shot sessions displayed:
  2. Select Export
  3. You will see the list of sessions with circles next to each session available, select the sessions for which you want to export the data
  6. Each session will be listed as a separate tab in the spreadsheet
