Bluetooth Garmin Dash Cam and Garmin Drive App Troubleshooting
null
Are you having any of these specific issues? If so, click on it below for troubleshooting. (If not, keep scrolling down to 'Level 1 - Try These Common Fixes')
Search for the Garmin Drive app in the Google Play or App Store to check for updates and apply them, if available.
Toggle Bluetooth and Wi-Fi Off, then Back On
This is typically found in your phone's Settings. Consult your phone manufacturer for assistance if you are unable to locate them.
If Using Wireless Apple CarPlay or Android Auto, Temporarily Disconnect
If you’re using wireless Apple CarPlay or Android Auto, your phone connects to your vehicle via Wi-Fi. This can make it tricky to connect your phone to your dash cam’s exclusive private Wi-Fi for tasks like viewing the gallery, aligning the camera, or updating the dezl or Garmin Drive app. To fix this, temporarily disconnect Apple CarPlay or Android Auto on your car’s screen. This will free up your phone’s Wi-Fi to connect to the dash cam.
If you don’t want to disconnect, try doing these tasks when your Apple CarPlay or Android Auto system is powered off.
Ensure the Dash Cam is Receiving Adequate Power
Dash cams without a screen may display a solid green light. This indicates the device is connected to a computer or another low-power USB outlet. The dash cam is not receiving enough power to pair with the Garmin Drive app.
Dash cams with a screen may display an image with the Garmin logo and garmin.com/express or garmin.com/dashcamvideos. This indicates the device is connected to a computer or another low-power USB outlet. The dash cam is not receiving enough power to pair with the Garmin Drive app.
If your dash cam is not receiving enough power, it is recommended to power it using the longer power cable and the Dual USB Adapter that came with it, plugging directly into a 12V power outlet or cigarette lighter outlet in the vehicle.
'Add Another Phone' - on the Dash Cams with a Built-In Display:
If 'Reconnecting' or 'Add Another Phone' displays, it is because it is remembering it had already connected to this or another phone.
Press the Save button next to Add Another Phone on the side of the device (bottom button) to continue the pairing process.
Proceed to the troubleshooting below if needed.
Level 2 - Next, Take These Steps if You are Unable to Connect to the Garmin Drive App:
Restore the Dash Cam
Restore a Garmin dash cam to its factory default settings.
NOTE: This will not delete saved or unsaved photos or videos.
Garmin Dash Cam Mini, Garmin Dash Cam Mini 2, Garmin Dash Cam Mini 3, Garmin Dash Cam Tandem
Simultaneously hold the large action button and the microphone button.
Plug in the dash cam while continuing to hold these buttons.
The light should turn red.
After several seconds the light will turn off.
Let go of the microphone button while continuing to hold the action button.
After several seconds, the light will turn green.
Let go of the action button.
The light will flash green as the dash cam resets and will then turn red.
Garmin Dash Cam x310
Use touchscreen of the dash cam to perform the following steps:
1. Swipe the touchscreen to the left, then select Settings
2. Select System
3. Select Reset
4. Select Reset again to reset the dash cam to default settings
All Other Dash Cams
Use the down button on the side of the dash cam to perform the following steps:
1. Select Settings.
2. Select System.
3. Select Setup (skip this step on some devices).
4. Select Reset.
5. Select Reset again to reset the dash cam to default settings.
Restore a Dash Cam Using the Garmin Drive App
Power the dash cam on.
In the Garmin Drive app, tap to expand the Vehicle and dash cam names; ensure it shows as connected.
Touch Settings below the dash cam name.
Touch Restore Defaults.
Touch Restore
It is recommended to forget the camera in the Garmin Drive app and forget the camera in the phone's Bluetooth/Wi-Fi settings before re-pairing the camera.
Forget the Dash Cam From Your Phone's Bluetooth Settings
Steps for clearing pairing history on the phone can vary by phone make/model.
To Clear Pairing History on Android:
Open the phone's Settings menu
Touch Connections (some phones skip this step)
Touch Bluetooth
Touch the gear icon next to the paired Garmin Dash Cam
Select the name of the listed Garmin Dash Cam instead on some Android phones
Touch Forget or Unpair
The Garmin Dash Cam will now be cleared from your phone's pairing history.
To Clear Pairing History on Apple:
1. Open the phone's Settings menu
2. Touch Bluetooth
3. Touch the info button ("i" circle icon) next to the paired Garmin Dash Cam
NOTE: There are variations in how different Garmin Dash Cams are listed in the phone's Bluetooth settings:
Garmin Dash Cam 47, 57, 67W, and Dash Cam Mini 2 will have two Bluetooth connections on Apple devices (ex. DC 67W and DC67W-12345-BT)
All other Garmin Dash Cam series will only have one Bluetooth connection (ex. DC X310)
4. Touch Forget this device
Forget all connections that apply to the dash cam you are clearing
Forget the Dash Cam From the Garmin Drive App
1. Open the Garmin Drive™ app
2. Touch the gear/wheel (Settings) in the upper right corner
3. Select the vehicle, then select your dash cam
4. Scroll to the bottom of the page, then touch Forget Device
5. Touch Forget Device again
6. Touch I don't have it anymore, then touch Remove Anyway
The dash cam will now be removed/forgotten from the Garmin Drive app.
Restart Your Phone
Be sure to completely restart your phone before proceeding.
Consult your phone manufacturer for assistance to fully restart your phone.
Re-pair the Dash Cam (Away From Other Bluetooth Devices)
Level 3 - The Above Did Not Resolve It - Let's Reset All and Start Fresh:
If desired you may bypass Level 2 and perform the steps in Level 3 instead.
Level 3 has all steps in Level 2, with the substitution of uninstalling / reinstalling the Garmin Drive app.
If you have additional devices paired in the Garmin Drive app, this will require them to be forgotten (Step 2) and re-paired (Step 6) before they can be used again.
2. Select System
3. Select Reset
All Other Dash Cams
1. Select Settings.
2. Select System.
4. Select Reset.
Touch Restore
Touch Bluetooth
2. Touch Bluetooth
For iPhone, and dash cams excluding the Garmin Dash Cam X110, X210, X310, Garmin Dash Cam Mini 3, or Garmin Dash Cam Live:
If you continue to have connection issues you may need to forget all Bluetooth pairings from your phone's Bluetooth setting until the dash cam pairing is successful.
Uninstall the Garmin Drive app
null
Restart Your Phone
