How Do I Manually Enter a Weight into Garmin Connect?
Your Garmin Connect™ account allows you to upload your body composition from a Garmin Index™ Smart Scale. You can also manually enter in your weight; however, any other body composition data must be uploaded using the scale itself. Select your platform below to reveal instructions to manually enter a weight into Garmin Connect.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Health Stats or Health & Performance.
  4. Select Weight.
  5. Select 3 blue lines stacked on top of each other (top right).
  6. Select Add a Weigh-in.
  7. Enter your weight.
  8. Select Save.
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Health Stats from the navigation bar on the left.
  3. Select Weight.
  4. Under weigh-ins, select Add Weight.
  5. Enter your weight.
  6. Select Save.
Sumber terkait
