Backing Up and Transferring BlueChart® Mobile Data
At times, it may be necessary to back up your user data in BlueChart® Mobile.  This is useful when it's desired to transfer the data to a new iOS device or if difficulties force you to delete and re-install the app.  Having a backup allows you to recover the data after the installation.
In order to back up the user data you will need to use the following steps:
  1. Open BlueChart Mobile
  2. Select Settings (Gear Icon)
  3. Select My Content
  4. Select Email all my content as GPX file
  5. Send the email to your own address to keep for your records
When the need arises to recover your data you can do the following:
  1. Open the saved email on the iOS device
  2. Press and hold on the GPX file attachment
  3. You will get a pop up and can select "Copy to BlueChart Mobile"
  4. Import the GPX file
  5. Select OK
It should then start transferring over to BlueChart Mobile and will be free to use once the transfer is complete.
