MediaMaster® Remote Compatibility
Consult the table below to determine which MediaMaster® remote controls can be used with each of the source units and which cables are required for connectivity. Download a printable version of the table using the link at the bottom of the page.
Source Unit | Equipped With | Remote Controller Options | Applicable Cables | Note |
MM105 MM105-HR MM55 MM55-HR | NA | MMR-25W | N/A | Pairs to source unit via BLUETOOTH® wireless technology |
MM105 MM105-HR MM100s MM100s-BE MM55 MM55-HR | 5-pin threaded connector (REMOTE) | MMR-20 MMR-20-BE MMR-10W | MMC-6 MMC-25 MMC-2Y | |
5-pin Micro-C connector (NMEA LEN 1) | MMR-11W | N/A | Connects directly to NMEA 2000 Micro-C connector of source unit | |
MMR-11W-N2K MMR-40 MMR-5N2K Compatible NMEA 2000 Multi-Function Display (MFD) | MMC-PN2K-6 MMC-PN2K-25 | Simulates an isolated, stand-alone NMEA 2000 network for the connection of one remote (MMR-40, MMR-11W N2K or MMR-5N2K) or NMEA 2000 compatible MFD with compatible MediaMaster source unit. | ||
Standard NMEA 2000 Micro-C Cables, connectors, etc. (not a JL Audio part) | Interfaces directly with NMEA 2000 networks. | |||
4-pin Deutsch connector (CAN) | MMR-40 MMR-5N2K Compatible NMEA 2000 Multi-Function Display (MFD) | MMC-PN2K-6 MMC-PN2K-25 | Simulates an isolated, stand-alone NMEA 2000 network for the connection of one remote (MMR-40 or MMR-5N2K) or NMEA 2000 compatible MFD with a compatible MediaMaster source unit; requires use of adaptor cable (MMC-DN2K-1 or MMC-DN2K-6) | |
MMC-DN2K-1 MMC-DN2K-6 | Permits direct interface with NMEA 2000 networks using standard NMEA 2000 Micro-C cables, connectors, etc. | |||
MM50 | 5-pin threaded connector (REMOTE) | MMR-20 MMR-20-BE MMR-10W | MMC-6 MMC-25 MMC-2Y | |
5-pin Micro-C connector (NMEA LEN 1) | MMR-11W | N/A | Connects directly to NMEA 5-pin Micro-C connector of source unit | |
MMR-11W-N2K MMR-40 MMR-5N2K Compatible NMEA 2000 Multi-Function Display (MFD) | MMC-PN-2K MMC-PN2K-25 | Simulates an isolated, stand-alone NMEA 2000 network for the connection of one remote (MMR-40, MMR-11W-N2K, or MMR-5N2K) or NMEA 2000 compatible MFD with a compatible MediaMaster source unit | ||
Standard NMEA 2000 Micro-C cables, connectors, etc. (not a JL Audio part) | Interfaces directly with NMEA 2000 networks | |||
MM80-HR | 5-pin Micro-C connector (NMEA 2K) | MMR-40 MMR-5N2K Compatible NMEA 2000 Multi-Function Display (MFD) | MMC-PN2K-6 MMC-PN2K-25 | Simulates an isolated, stand-alone NMEA 2000 network for the connection of one remote (MMR-40 or MMR-5N2K) or NMEA 2000 compatible MFD with a compatible MediaMaster source unit. |
