Pairing and Using the Alpha 10 with the Garmin Explore App
Using an Alpha® 10 dog tracking handheld and the Garmin Explore™ app, you can view a map of your live hunting activities right on your smartphone. The Garmin Explore app has many helpful features such as marking waypoints, reviewing previous activities, creating routes, and downloading higher grade maps. The following guide will get you started with pairing and using the Alpha 10 handheld with the Garmin Explore app.
The Garmin Explore app does not provide controls for training commands such as tone, vibration, or stimulation.
Before getting started download and install the Garmin Explore app from your phone's app store.
App Store Icon Google Play Icon
Pairing the Alpha 10 Handheld With a Smartphone
IMPORTANT: The Alpha 10 handheld must be paired directly through the Garmin Explore app, not directly from the Bluetooth settings in the phone settings.
Instructions for pairing will vary slightly depending on whether or not you have used the Garmin Explore app previously.
First Time Users
  1. Install and open the Garmin Explore app.
  2. Allow any app permissions when prompted.
  3. Select Create Account.
    • NOTE: If you already have a Garmin account or have previously used other Garmin apps, you can select Sign In (or Continue as ['username'], if prompted).
  4. Tap Next after reading and agreeing to the EULA.
  5. Tap Enable Cloud Storage (or Not Now).
  6. Continue selecting Done to proceed through the information about new app features.
  7. Select Add Device when prompted.
    The app will then begin searching for devices.
  8. On the Alpha 10, pressthe Menu button, then select Setup > Phone.
  9. On the Alpha 10, ensure Status is On, then select Pair Phone.
  10. In the Garmin Explore app, select Connect It and follow the prompts to complete the setup.
The Alpha handheld will now be paired with the Garmin Explore app.
Existing Garmin Explore App Users
  1. Open the Garmin Explore app.
    • If prompted, read and agree to EULA, and sign in.
  2. Select Watch and Handheld Icon Devices.
  3. Select either + Pair a New Device or Plus Symbol.
  4. On the Alpha 10, pressthe Menu button, then select Setup > Phone
  5. On the Alpha 10, ensure Status is On, then select Pair Phone.
  6. In the Garmin Explore app, select Connect It and follow the prompts to complete the setup.
Using the Garmin Explore App
Some of the main features of the Garmin Explore app include:
  • Creating waypoints and routes/courses
  • Reviewing recorded tracks
  • Downloading detailed topographic and satellite imagery maps directly to the smartphone (see instructions below )
  • Organizing data into Collections to show or hide previous activities on the map
  • Syncing data to the Garmin Explore website for cloud based storage
Extra features and tools will be enabled in the Garmin Explore app when an Alpha 10 handheld has been paired:
  • Shows Dog Status icon – treeing, pointing, sitting
  • Shows Dog Name
  • Dog Track Color matches the colors on handheld – red, blue, black
  • You can adjust how long the dog tracks show on the map
  • Dog movement Speed Indicator
    • Any part of the track that shows a segment of the dog moving faster than a certain speed will show up as a thicker line on the map
    • Useful to know if the dog is chasing something during a hunt
    • Choose either faster than 5 mph, 10 mph, 15 mph, or Off
      2. Select Unfolded Map Symbol Map.
      3. Select Map Layers.
      4. Select three dots.
      5. Select Map Settings.
      6. Select Line Display Settings (Android) / Dog Mode Settings (iOS).
      7. Select Speed Indicator.
  • Dog Hunts saved as an Activity
  • Play Back feature: Plays back the dog's hunting activity
    1. Select Bookmark Symbol Saved.
    2. Select the name of the hunt you want to review.
    3. Select the dog you want to review from the List.
    4. Touch the play button.
Downloading Topography and Satellite Imagery Maps to the Garmin Explore App
Detailed topographic maps of North America, color aerial imagery (US only), and detailed maps of the rest of the world can be downloaded for viewing and use in the Garmin Explore app. Use the instructions below to download maps and manage them in the app.
Downloading Maps
NOTE: A data connection is required for downloading maps. Due to the size of the downloads, Garmin highly recommends using a high-speed Wi-Fi connection. Maps downloaded to the Garmin Explore app cannot be loaded to a Garmin.
  2. Select an option:
    • Select Down Arrow Offline Maps > Plus Symbol New Offline Map.
      -OR-
    • Select  Unfolded Map Symbol Map > Plus Symbol > Create Offline Map.
  3. Drag the map to view different areas.
    Pinch or spread two fingers on the screen to zoom in and out of the map.
  4. Swipe up and select which layers to download.
    NOTE: Tap Information to the right of a layer for a description.
    New Offline Map Screen
  5. Once you have selected the area and layers to download, select Save.
Sumber terkait
