Charging the inReach Mini 2
NOTE: To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer. The device does not charge when it is outside the approved temperature range (0° to 45°C or 32° to 113°F).
Charging the inReach® Mini 2 Satellite Communicator
- Lift the weather cap
- Plug the small end of the power cable into the charging port
on the device.
- Plug the other end of the power cable into a compatible AC power adapter.
- Plug the AC power adapter into a standard wall outlet.
- Charge the device completely.
Saving Energy While Charging the inReach Mini 2 Handheld
- Connect your device to an external power source.
- Hold the power button until the screen turns off.
The device goes into a low power, battery charging mode, and the battery gauge appears. - Charge the device completely.
