Searching for POIs near a Different Location on an Automotive Device
Automotive devices can search for Points of Interest (POIs) away from the device's current location, For example: at a destination miles away.
To Search for POIs Near a Different Location on an Automotive Device:
  1. Touch Where To? or Search
    • Touch Apps then Apps again first on some devices
  2. Touch Near, Near Me,   Searching Near, Nearby, or Drive 53 Search Near at the top
    • Some devices may require you to touch the menu button (three horizontal lines) before touching Near on this step.
    • On some devices, touch Select a Location to see search options.
  3. Select the desired option (some options are not available on all devices)
    • Where I Am Now searches near your current location (this is the default setting)
    • A Different City / A Different Town / Near a City searches near a city you enter
    • Home searches near the Home location set on the device
    • Recent Destination searches near a selected location listed in your recent destinations
    • Favorite/Favorite Destination/Saved Place/Waypoints searches near a location you've saved
    • Address searches near an address entered on the device
    • Intersections searches near an intersection entered on the device
    • Coordinates searches a set of coordinates entered on the device
    • My Active/Current Route/ Near My Route searches along the calculated route
      • This option is only available when navigating on an active route
    • A Time Ahead searches along the calculated route at a selected time ahead
      • Route must be over 15 minutes
      • Time ahead can be selected at 15 minute intervals
    • My Destination / Near Destination searches along the calculated route, but results start near the destination and work backward along the route
    • Upcoming Exits searches near upcoming exits on an active route
    • Browse Map searches near a location selected on the map page of the device
    • Select a Location searches near a home address, recent address, intersection, location browsed on the map, a specific address entered, a saved address, or coordinate
To begin searching near your current location once again, simply return to the main menu to restore the default.
