Connecting a vivoki to the Garmin Connect App
To sync the step data from your vivoki to Garmin Connect using your phone you will need to pair it to the Garmin Connect™ app.
vivoki Pairing Instructions
  1. Download the Garmin Connect app from your phone's app store.
  2. Once installed, open the app and either create an account or sign in to your existing account.
  3. Select an option to add your device to your Garmin Connect account:
    • If this is the first device you have paired with the Garmin Connect app, select Add Device from the main page.
    • If you have already paired another device with the Garmin Connect app, select the three bars in the top left (Android) or More in the bottom right (iPhone) > Garmin Devices > Add Device.
  4. Select Browse all compatible devices.
  5. Select vivo.
  6. Select vivoki.
  7. Confirm your profile information and select Next.
  8. Double tap on your vivoki to wake it up.
  9. From the app select Start.
  10. Follow on-screen instructions to pair your vivoki with your mobile device.
Once the vivoki is paired to your phone, the step data recorded will upload each time you sync with the app.
How Do I Perform a Sync with the App?
To synchronize your step data follow these steps:
  1. Open the Garmin Connect App from your mobile device.
  2. Tap the vivoki two or three times in succession until the LEDs flash.
  3. From the application wait for the vivoki to automatically connect via Bluetooth to your mobile device.
  4. The device will take only a few seconds to sync the data.
Once connected, the step data will be updated in the app.
Sumber terkait
