Delta and Pro Series Collar Light Sequences
The Delta® and Pro series dog collars will display different light sequences to let you know the status of the collar while in use or during charging. The different colors and flashes are described in the tables below.
Light sequences when in use:
Green flash | Battery has good charge |
Yellow flash | Battery has less than 50% remaining |
Red flash | Battery should be charged soon |
Rapid red flash | Battery depleted and training features disabled |
Light sequences when in BarkLimiter mode*:
Solid green | Correction is being applied |
Green or amber flash | Motion detected but no correction applied |
Light sequences when charging:
Solid Red | Charging |
Solid Green | Fully Charged |
Refer to the device owner's manual for information about light sequences and colors when using BarkLimiter mode or producing stimulation.
*When in BarkLimiter™ mode the collar will not flash to indicate battery status.
