Connections Leaderboard in Garmin Connect
The Connections Leaderboard in your Garmin Connect™ account keeps a weekly total of your steps and distance from select activities so you can see how you measure up with your connections. The leaderboard resets to zero each week on Sunday at midnight in your time zone. Select a platform below for steps on how to access your current Connection Leaderboard results.
NOTE: Changing the First Day of the Week user setting in Garmin Connect will not be applied to weekly challenges.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select Challenges from the tab bar menu at the bottom of the page or from the More menu in the bottom right.
  3. Under My Challenges, select Weekly Leaderboard.
  4. Here you will see your current steps ranking based on the last time you synced.
    • To change the data from steps, select Steps at the top of the page, then select your desired option.
If you do not see your data in the leaderboard you may need to update your Privacy Settings. See Related content below for steps on how to change your Privacy Settings.
Garmin Connect Web
  1. From a web browser sign into your Garmin Connect account.
  2. Select Connections from the navigation bar on the left.
  3. View the Weekly Leaderboard.
    • To change the data from steps, select the Steps dropdown, then select your desired option.
  4. Select View Previous to see last week's results.
  5. Select View Current to return to your current week.
If you do not see your step data in the leaderboard you may need to update your Privacy Settings. See Related content below for steps on how to change your Privacy Settings.
Sumber terkait
