Understanding the LED Colors on the Garmin Dash Cam Mini 2
The Garmin Dash Cam™ Mini 2 has a status LED light below the large save button that displays different colors depending on the device status. Below is a breakdown of the different LED meanings. Some colors can have more than one meaning.
Green
  • The device is connected to a computer.
    • The computer will not provide enough power to pair the dash cam with the Garmin Drive app
  • The memory card is being formatted.
  • If stuck on this color while plugged into the vehicle, see Garmin Dash Cam Power Issues.
Mini 2 Green Bottom
Flashing Green
  • The device is booting.
Mini 2 Booting
  • An update is being installed.
Mini 2 Updating
Red
  • Video is recording.
Mini 2 Recording Audio Muted
  •  Audio is being recorded.
Mini 2 Recording
Flashing Red
  • A photo or video is starting to be saved.  The animation will play for 2 seconds.
  • An incident has been detected.
Mini 2 Saving in Progress
  • Saving a photo or video is in progress.  The animation will play for the duration of the save.
Mini 2 Parking Mode
Parking Mode 2
Red with Flashing Yellow
Mini 2 Low on Space
See SD Memory Card Compatibility for the Garmin Dash Cam 46, 47, 56, 57, 66W, 67W, Mini, Mini 2, and Tandem to ensure a compatible card is being used.
See the owner's manual or Formatting a microSD card on a Garmin Dash Cam Mini or Garmin Dash Cam Mini 2 for instructions to format the memory card and update the software.
Flashing Yellow/Flashing Yellow and Green
  •  There is a problem with the memory card.
Mini 2 error1
Mini 2 error 2
See Flashing Yellow/Yellow and Green Light on a Garmin Dash Cam Mini and Garmin Dash Cam Mini 2 for troubleshooting steps.
Cyan
  • Voice Command
ASR 2
Blue/Flashing Blue and Red
  • The device is in Wi-Fi sharing mode.
Mini 2 Wi-Fi
  •  The device is in Bluetooth pairing mode (recording audio).
Mini 2 Pairing Recording Audio
  •  The device is in Bluetooth pairing mode (not recording audio).
Mini 2 Pairing
No Light
  • The camera is not connected to a power source.
  • See Garmin Dash Cam Power Issues if the Garmin Dash Cam is connected to power and has no light.
Mini 2 Off
Sumber terkait
