Understanding the Golf Performance Widget
The Golf Performance widget displays your handicap index, drive accuracy, approach, and GIR (Greens In Regulation) to give you a better understanding of how your golf ability is trending. The information displayed in the Golf Performance widget is calculated by the Garmin Golf™ app, and a connection to the app is required.
Adding the Widget
  1. Swipe Up/Down from the watch face
  2. Select Edit
  3. Touch Golf Performance
    NOTE: The order of widgets can be changed by touching on the widget name, then scrolling the screen, then touching the widget name again.
Once the Golf Performance widget has been added, scroll to and select the widget to view your performance stats.
