Using the Dual Orientation Display on an Automotive Device
Garmin automotive devices with an Android operating system have an option in the Display settings menu called When device is rotated or Auto-rotate screen. This setting enables the screen to rotate automatically between portrait and landscape display modes based on the device's orientation or sets the device to remain in the current display mode regardless of its orientation. See the owner's manual for instructions to adjust the display settings.
NOTE: For a horizontal view, the device would need to be upright with the Garmin logo (on the face of the device) and the power button on the left side. To change to a vertical position, rotate the device to the left, then rotate the device back to the right to go back to a horizon view.
Devices With Automatic Dual Orientation Display
Dual orientation display devices listed below can be set to automatically change orientation. They can also be locked to either horizontal or vertical display.
Note: Devices can only be rotated 1/4 turn counterclockwise to change from horizontal to vertical. They cannot rotate upside down or clockwise.
To Change the Display Orientation on Most Devices with This Feature:
Touch Settings
Touch Device
Touch Display
Touch When device is rotated
Touch the desired setting
To Change the Display Orientation on the Camper 895 and Camper 1095 Caravan and Motorhome Sat Nav, RV 895 and RV 1095 RV Navigator, dēzl™ LGV810, dēzl™ OTR810, dēzl™ LGV1010, dēzl™ OTR1010, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition, and Tread® - SxS Edition GPS Navigators:
Touch Settings
Touch Device
Touch Display
Touch Auto-rotate screen to toggle on and off
dēzl™ Series
dēzl OTR800 GPS navigator
dēzl LGV800 GPS navigator
dēzl OTR810 GPS navigator
dēzl LGV810 GPS navigator
dēzl OTR1000 GPS navigator
dēzl LGV1000 GPS navigator
dēzl OTR1010 GPS navigator
dēzl LGV1010 GPS navigator
Camper/RV Series
Camper 890 caravan and motorhome sat nav | RV 890 RV navigator
Camper 895 caravan and motorhome sat nav | RV 895 RV navigator
Camper 1090 caravan and motorhome sat nav | RV 1090 RV navigator
Camper 1095 caravan and motorhome sat nav | RV 1095 RV navigator
Tread® Series
Tread - Overland Edition
Tread - SXS Edition
Tread XL - Overland Edition
Tread XL - Baja Chase Edition
Tread XL - Baja Race Edition
Devices With Dual Orientation Display via Battery Power
The screen can be rotated from landscape to portrait mode with the mount attached or unattached when not viewing the map screen.
The screen cannot be rotated with the mount attached or unattached when viewing the map screen. The device will always be in landscape mode when viewing the map screen.
To Change the Display Orientation:
Touch Settings
Touch Device
Touch Display
dēzl™ Series
dēzl™ 780 LMT-S GPS navigator
dēzlCam™ 785 LMT-S GPS navigator with camera
Overlander® Series
Overlander® GPS navigator
Camper/RV Series
Camper 785 & Traffic caravan and motorhome sat nav with camera | RV 785 & Traffic RV navigator with camera
