Rally 200 Series: Error 1024 During Calibration
While trying to calibrate a Rally™ Power Meter, a 1024 Error code may appear. This may be caused by the following.
Drained battery in the right pedal
An attempt was made to update pedals before installing, and only the left pedal was awake
The wrong pedal ID was typed in when pairing the pedals
The system will stop trying to update after a while of being unable to do so. Some common troubleshooting steps for this issue are listed below.
Remove and re-insert batteries in both pedals
Wake pedals
Un-pair from the connected app or head unit and re-pair (This may need to be attempted a couple of times)
Ensure the proper ID is entered for the right pedal
