How to Install Connect IQ Content Using Garmin Express
Connect IQ™ apps can be downloaded and installed from the Connect IQ Store using the Garmin Express™ program.
Instructions to Install Connect IQ Apps Using Garmin Express Software
  1. Connect the device to the computer using the USB/Data cable.
  2. Open Garmin Express program.
  3. Select the device.
  4. Select IQ Apps.
  5. Select Get More Apps.
  6. Choose an app to install, then select Download.
  7. Review and Accept Terms if required.
  8. Grant Permissions (if required) by clicking Allow.
  9. From Garmin Express program, click Install All which will sync the device.
Once installed on the device, you may need to configure your device to use the Connect IQ app. Storage space and app capacity varies by device model.
NOTE: Certain requirements must be met to access the Connect IQ Store. Apps will only be available for Connect IQ compatible devices. When using a computer, Garmin Express software must be installed and up to date.
How to Apply the Connect IQ Apps
Once you have installed the Connect IQ app, you will need to refer to your owner's manual for steps to apply your widgets, data fields, watch faces or applications.
Sumber terkait
