My Montana 600 Series is in the Wrong Language
If your Montana® 600 series handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below (with the device in portrait mode), see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
  1. If necessary, tap X or Back Arrow until you reach the main menu.
  2. From the main menu, tap Arrow Bracket to open the application drawer.
  3. Tap Wrench and Screwdriver.
  4. Tap Gear Wheels.
  5. Tap the second item in the menu.
  6. Tap the desired language.
Sumber terkait
