My eTrex is in the Wrong Language
If your eTrex® outdoor handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the eTrex. You will be prompted to select a language after the reset, during initial setup.
NOTE: These steps apply to the eTrex 10, 20, 20x, 22x, 30, 30x, and 32x. If you have an eTrex Touch, see - My eTrex Touch is in the Wrong Language. If you have an eTrex SE or eTrex Solar, see - My eTrex SE or eTrex Solar is in the Wrong Language.
Changing the Language
  1. Press the Menu key twice to open the main menu.
  2. Use the thumb stick to scroll to Wrench, then press the thumb stick to select it.
  3. Select Gears.
  4. Scroll to and select the third item in the menu.
  5. Scroll to and select the desired language.
Sumber terkait
