Sharing Saved Places/Routes From a Garmin Camper/RV Device
You can import and export GPX files like waypoints and routes you have created with other Garmin users in two ways: through the Garmin Drive App or with a memory card.
To Share a Route Using the Garmin Drive App
1. Touch Route Planner
2. Touch the wrench in the top left corner
4. Touch Share
5. Touch Garmin Drive
6. Name the gpx file that will be shared and select done
7. Select the trips you want to share
8. Touch Done
9. Touch OK
10. Open the Garmin Drive App on your phone
11. Touch Share
12. Follow the on-screen instructions to share the .gpx files
13. The receiving Garmin user can then open the file with the Garmin Drive App
14. Touch Send in the Garmin Drive App
The trip will now be found in Trip Planner on the receiving device.
To Share a Saved Location With the Garmin Drive App
1. Touch Where To?
2. Touch Saved
3. Touch the menu button in the top left corner
4. Touch Share
7. Select the waypoints you want to share
8. Touch Done
9. Touch OK
11. Touch Share
12. Follow the on-screen instructions to share the .gpx files via email
The waypoint will now be found in your Saved places on the receiving device.
To Share a Route Using a Memory Card
1. Insert a compatible microSD card into the memory card slot on your device
2. Touch Route Planner
3. Touch the wrench in the top left corner
4. Touch Share
6. Touch Memory Card
7. Name the gpx file that will be shared and select done
8. Select the trips you want to share
9. Select Done
To Share a Saved Location Using a Memory Card
2. Touch Where To?
3. Touch Saved
4. Touch the menu button in the top left corner
5. Touch Share
8. Select the waypoints you want to share
9. Touch Done
