The Creative Golf Garmin Connecter is used to bridge the connection between the Garmin Golf app and Creative Golf on your PC.
Open the Garmin Golf app.
Select
Select Other Simulators.
Select Creative Golf 3D.
Select Play Now.
The Garmin Golf app will direct you to install the Creative Golf Garmin Connecter from the phone's app store.
Once downloaded, select Open.
On the Creative Golf Garmin Connecter app, select Creative Golf.
NOTE: The Approach R10 should automatically connect. If it does not, ensure the Garmin Golf app is running in the background and connected to the device.
Scan the QR code from the Creative Golf simulator on your PC using your phone's camera or enter the IP address.
For adding the IP Address manually, that can be located on your computer with these steps:
Select Start.
Select Settings.
Select Network & Internet.
Select Wi-Fi.
Select the Wi-Fi network you're connected to.
Under Properties, look for your IP address listed next to IPv4 address.
After successfully connecting make sure the Approach R10 monitor is flashing green. If this is not the case, hold the button on the back of the Garmin Device to power it off, and then again to power it back on.
