How to Reset an Approach G10 or S10
There are two resets that can be performed if you are having issues with a Garmin Approach® G10 or S10 golf device not functioning as expected. A forced restart is suggested when the Approach device is unresponsive, or will not power on or off. A master reset is suggested for problems with satellite reception, general functionality issues, or restoring factory default settings (all user information, with the exception of saved scorecards, will be erased with a factory reset).
Forced Restart Steps
null
Master Reset Steps
null
The device should now be reset to default factory settings, and should function as expected. Leave the device outside with a clear view of the sky for up to 20 minutes to acquire satellite data.
null
