Formatting a microSD/SD Memory Card
Sometimes a microSD/SD card may require formatting before it can be used with a Garmin device.
NOTES:
  • These instructions are only for formatting a microSD/SD card.
  • Do not format any Garmin mass storage device.  Formatting the device will cause the device to become inoperable.
  • It is recommended to use cards 32 GB or smaller for maps and other downloaded content. A larger card may be used for recording videos on compatible devices. See SD Memory Card Sizes for Automotive Devices for more info on compatible sizes.
If the microSD/SD card is intended for use as a camera card for the Garmin DriveAssist™ 50LMT or Garmin DriveAssist™ 51 see Formatting the Camera microSD Memory Card or Map microSD Memory Card on a Garmin DriveAssist Device.
If the microSD/SD card is intended for use as a camera card for the dezlCamLMTHD or the nuviCamLMTHD see null.
To Format a microSD/SD Card on a Windows Computer
1. Place the SD card into the SD card slot in the device
For devices that connect to the computer in MTP (Media Transfer Protocol) mode, a separate memory card reader must be used. An MTP device will show an orange computer connection icon on the screen while it is plugged into a computer.
2. Connect your device to the computer with a USB cable
If your device is not recognized by the computer, see the FAQ Automotive Device Not Detected by Garmin Express on a Windows Computer.
3. Press the Windows key + E
4. If using Windows 10 or newer, click This PC
5. Locate the drive representing the SD card
To determine which drive is the SD card, remove the SD card from the device and observe which drive disappears from the list. Insert the SD card again to continue.
If the SD card is not recognized here, see the FAQ SD Card Not Detected or Recognized by Garmin Express.
With Card Inserted
Without Card Inserted
6. Right-click on the SD card drive. The drive letter pictured is an example; the memory card may be assigned a different drive letter.
7. Select Format
8. Verify File System is FAT or FAT32
Format the microSD/SD card to the FAT or FAT32 format. A 2 GB or less card can be formatted in FAT or FAT32. Cards larger than 2 GB should be formatted in FAT32.
If an option is not given to format the card in FAT32, it is recommended to switch to another SD card no larger than 32 GB. Cards larger than 32 GB (for video recording) are typically formatted in exFAT.
9. Change Allocation unit size to Default allocation size
10. Ensure Quick Format is checked
11. Select Start
If at any point during the format process an error is received or formatting the SD card fails to resolve the issue, try a different SD card. These steps will format the microSD/SD card to be readable by the Garmin device.
To Format a microSD/SD Card on a Mac OS X Computer
If your device is not recognized by the computer, see the FAQ Automotive Device Not Detected by Garmin Express on a Mac.
3. Open Spotlight by clicking the  search icon in the upper right corner of the screen, or by  CMD + SPACE on the keyboard
4. Type Disk Utility (in the Spotlight search box)
5. Press Enter or Return on the keyboard
6. In Disk Utility, click the parent icon for the SD card in the sidebar on the left
The parent icon is the one that is not indented. This is not necessary on macOS 10.12 and newer.
mac no name 2
7. Select on the Erase option on the right
mac erase
8. In the Format drop-down menu, select MS-DOS (FAT)
mac format fat
9. Select Erase
mac final erase
The SD card will now be formatted and readable by the Garmin device.
If at any point during the format process an error is received or formatting the SD card fails to resolve the issue, try another SD card.
Sumber terkait
