Charging an Automotive Device
Garmin recommends always using the vehicle power cable packaged with your device, or a Garmin-branded AC power charger. Full power will ensure your device gets the best signals from GPS satellites and traffic updates.
Third-party cables or adapters may not charge the device or put it in the proper state to receive updates.
null
This Video is a Quick and Easy Way to Learn about Charging your Device.
There are Two Ways to Charge Your Automotive Device's Internal Battery:
Use the vehicle power cable that came with your device.
| Use a Garmin-branded AC power adapter accessory, such as a wall power adapter.
Note: Place the unit screen side down when charging to reduce stress on the device's USB port. |
Temperature can affect the charging of a device. The battery won't charge if it registers a temperature of 0°C (32°F) and below or 45°C (113°F) and above. See Charging Factors for an Automotive Device for more information about the effects of temperature on your device.
The battery will not drain when an automotive device is connected to external power.
See How Can I Tell Whether My Automotive Device is Charging? to ensure your device is charging properly.
Your device will be placed into Standby mode when the power button is pressed and released. Fully power off the device before storing it to preserve the charge on the battery. Press and hold the power button for 3-5 seconds. Then touch Off or Power Off.
A Garmin AC adapter or replacement cable can be purchased at Garmin’s online store.
