Add, Edit, or Remove Golf Clubs for Your Garmin Golf Product
Many Garmin golf products have the ability to add clubs to track statistics. Some Garmin products will add clubs through the settings on the product. Other Garmin products that are compatible with the Approach® CT1 tags or Approach® CT10 club sensors will track club information when paired to or connected with the golf product. Refer to your owner's manual for steps on adding clubs to your golf capable product.
Once clubs are added to your Garmin product, you can edit the clubs to change the club type, shaft flex, shaft length, or nicknames within the club list. You can also retire or turn off the active indicator on clubs if you are no longer using them or would like to start over with fresh statistics for a specific club. The sections below outline editing and removing clubs with either the Garmin Golf™ app or your Garmin Connect™ account using a web browser.
If you are using the Approach® CT1 club tracking tags there are editing options available directly on compatible watches. For more information see below .
NOTE: The entire club list will appear on your device. If you are changing to a new set of clubs, we suggest retiring or turning off the active indicator on the old clubs. Setting your clubs to inactive or retiring them will allow you to see stats for the clubs but they cannot be reinstated.
Garmin Golf App
Adding Clubs
  1. Open the Garmin Golf app
  2. Select Profile.
  3. Select My Bag.
  4. Select Plus Sign.
  5. Choose a club.
  6. Select Add after entering the club information.
Editing Clubs
  2. Select Profile.
  3. Select My Bag.
  4. Select a club to edit.
  5. Select Edit.
  6. Make changes to the club information.
  7. Select Save
After making changes your golf device will need to be synced through the Garmin Express™ program, Garmin Golf app, or Garmin Connect app for the changes to be fully applied.
Garmin Connect Website
Adding Clubs
  1. From a web browser sign into your Garmin Connect account.
  2. Select Gear from the left side of the page Running Shoe and Gear Icon.
  3. Select Golf Clubs.
  4. Select +Add Gear.
  5. Select Golf Clubs from the Gear Type dropdown.
  6. Select Save after entering the club information.
Editing and Removing Clubs
  4. Select to Pencil edit or Three Dots to retire or remove clubs.
  5. Select Save after making edits.
Approach® R50
Adding Clubs
  1. Select the menu button on the bottom right corner of the screen.
  2. Select My Bag.
  3. Select Plus Sign.
  4. Choose a club type.
  5. Select the checkmark in the top right corner after entering the club information.
Editing Clubs
  2. Select My Bag.
  3. Select a club to edit.
  4. Make changes to the club information.
  5. Select the back button in the top left corner to cave your changes.
Changing Approach® CT1 Club Tag Names
The Approach® CT1 tags each come with a label corresponding with one of 16 club types. This label can be found on the underside of the tag. Regardless of this label, you can edit which tag corresponds to your clubs by following the steps below for your compatible watch.
Approach® S44 | Approach® S50
  1. Press and hold the Top button.
  2. Select Settings.
  3. Select Golf Settings.
  4. Scroll down and select Club Tracking.
  5. Select Approach CT1.
  6. Select Manage Tags.
  7. Tap the tag you want to edit to the face of the watch.
  8. Select the pencil icon Pencil Icon to change the club type.
