Understanding and Using Flight Apex With the Xero A1i PRO
Flight Apex is an advanced feature of the Xero® A1i PRO bow sight. Flight Apex displays a flashing point above the Aim Point that shows the highest estimated position the arrow reaches during its flight path.
Example
Flight Apex PIC
Enabling Flight Apex
This Flight Apex feature is useful for shooting through dense cover, or when the view is obstructed, as the highlighted upper arc of the arrow's flight path will allow the you to tell if there is an obstruction in the vertical flight path of the arrow.
NOTE: The Dynamic Level feature will be disabled while Flight Apex is active. See Understanding and Using the Dynamic Level Feature of the Xero A1i PRO for more information on the Dynamic Level feature.
  1. Select Xero A1i PRO ICON SettingsMenu from the Main Menu.
  2. Select Pro Settings.
  3. Select Flight Apex On.
    Flight Apex ON
Sumber terkait
