Navigational Avoidances on Garmin Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a checkmark beside them will be avoided whenever possible.
A detailed video tutorial discussing route settings is available below:
To locate the Avoidance menu:
- Open the device's Settings menu
or
- Touch Navigation
- Touch Route Preferences
- Touch Avoidances
- Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available avoidances:
- U-Turns – Avoids calculating routes that require a U-turn
- Highways or Motorways – Avoids highways, interstates, freeways, motorways, and other major routes
- Ferries – Avoids routes that require a ferry crossing
- Carpool Lanes or Car Share Lanes – Avoids lanes designated specifically for carpooling
- Unpaved Roads – avoids unpaved roads (gravel, dirt, etc.)
The following avoidances are available elsewhere in the Route Preferences menu:
- Custom Avoidances1 – Feature available on some devices that will allow you to select specific areas or lengths of road to avoid
- Environmental Zones2 – Avoids areas with certain travel restrictions
- Toll Roads or Tolls and Fees – Avoids toll roads and certain specified congestion zones
Note: Devices will only avoid selected items when it is possible. For example, if you have U-turns selected as an avoidance, but there is not an alternate route available that excludes U-turns, the device may still direct you to make a U-turn.
1 For more information about custom avoidances and steps to set them up, refer to your device's owners' manual. Custom road avoidances may need to be re-set after each map update, but they should remain intact and accurate after map updates.
2 More information about Environmental Zones can be found in the following FAQ: Environmental Zones
