Locating the SSID and Password for Your Router
An SSID is the name assigned to a Wireless Network. You will need to look for the SSID when setting up a Wi-Fi® connection on a Garmin® device.
All routers come with a default name and password, but can be changed during the initial setup. Depending on the manufacturer, the location of the default network name and password can be found in several places. If the router has not been configured, check the side or bottom of the router. The information may also be included in the router's original documentation, or in the Support section of the manufacturer’s website.
If the router was setup by a technician, and the name and password were changed, refer to any documentation provided by the technician, or contact the technician for more information.
For more information on setting up a Wi-Fi connection, see Related content below.
Sumber terkait
