How to Reset the Rino 700
There are a few instances in which it is necessary to perform a full reset on a Rino® 700 outdoor handheld, including the following:
  • Not receiving a satellite signal
  • Restoring the factory default settings
  • Not functioning properly
The information and steps below will walk you through backing up your data and resetting.
Before Resetting
Performing a full reset can cause user data loss. User data is waypoints, routes, tracks, contacts, and geocaches.
It is recommended to back up important data with BaseCamp™ software before resetting. For steps, see Related.
NOTE: Contacts cannot be backed up and will be erased during a reset. Contacts can be re-added by accepting the prompt to save the contact once the other device has initiated a transmission.
If removing data is desired to eliminate corrupt data or free up space, see Related.
Performing a Full Reset
  1. Power off the Rino handheld
  2. Press the MenuEnter,1 and Power buttons simultaneously
    • Rino 700 Device Operation
      Rino 700 Device Op
  3. As it powers on, Release the Power Button
  4. Continue to hold the menu and Enter
  5. Release all buttons once the Do you really want to erase all user data? message appears
  6. Select Yes
The Rino is now reset. You will want to take the Rino outside in a clear view of the sky for a minimum of 20 minutes to re-acquire satellite data.
1 Enter is pressing in the center of the thumbstick. It is important that the thumbstick does not move to any side, as this will prevent the reset from working.
Sumber terkait
