microSD Card Requirements for the Garmin fleet 770, Garmin fleet 780, and Garmin fleet 790
A Garmin fleet device can use the minimum/maximum (max) card size as listed below.
Important information:
- When using a card with a larger capacity, if there are too many files and/or large files on the card, the device may draw maps more slowly.
When updating the maps on a device, an SD card with at least 4 GB of space must be used.
See Using a 64 GB microSD/SD Memory Card or Larger for devices below compatible with 64 GB microSD/SD Memory Cards or larger.
- Garmin Express will only install a map update to a memory card if there is not enough space on the internal storage of the device.
- Maps cannot be moved from the device to a memory card manually.
- Instructions on where to insert your device's SD card/microSD card can be viewed in your device's Owner's Manual.
- SD/microSD cards can be purchased from Garmin or other retailers. Garmin offers the following SD/microSD cards for purchase.
4 GB microSD Class 4 Card with SD Adapter
8 GB microSD Class 4 Card with SD Adapter
16 GB microSD Class 10 Card with SD Adapter
Model | Maximum Capacity | Card Type | Class |
Garmin fleet 770, 780, 790 | 32 GB | microSD | Class 2 to 10 |
Garmin fleet 780, 790 (Camera SD card slot) | 128 GB | microSD | Class 10 |
