Honda Map Update USB Not Detected by Garmin Express on a Mac
USB communication issues can prevent your USB drive from being detected by the Garmin Express™ application.
Visit https://honda.garmin.com/honda before starting the map update process for instructions on preparing your USB flash drive.
Using the Same USB Flash Drive for the Honda Map Update /Formatting the USB Flash Drive
When doing a Honda map update you may use the same 16 GB USB flash drive that was used for a previous map update.  Prior to using the flash drive for the new update however, you will want to completely format the drive.
See  Formatting a USB Drive for a Honda Navigation System
Once the flash drive has been formatted, you will want to follow the full update process found at https://honda.garmin.com/honda/
Ensure the Mac Recognizes the USB Flash Drive
The USB drive will be displayed as a removable disk drive in Finder when properly connected to a Mac computer.
To Check Whether the Mac Recognizes the Connection:
1. Connect the USB flash drive to the computer
2. Click the Finder icon on the dock
red box around smiley face icon
3. Click Go in the menu bar at the top of the computer screen
MAC menu bar with Go selected
4. Click Computer
MAC Go menu with Computer selected
The USB drive will display as a disk drive icon.
Mac Finder window with available disk drives displayed
USB Drive Does Not Display as a Drive in Finder
Ensure the USB port is Working Properly:
  • Try a different USB port on your computer and/or test the USB port with a different USB device.
  • Avoid connecting through a USB hub, USB extension cable, keyboard, or monitor.
  • On a desktop computer, use the USB ports on the back of the computer.
Restart the Computer and Try Again:
1. Click the Apple icon in the menu bar
2. Click Restart...
3. Click Restart to confirm
USB Drive is Recognized by Computer but Not by Garmin Express
See Garmin Express Not Detecting Devices on Newer Mac OS if you are on Mac Catalina, Big Sur, or newer.
Ensure Garmin Express is Up to Date:
1. Open Garmin Express
2. Click Garmin Express in the Apple menu bar
Red box around Garmin Express
3. Click About Garmin Express
Red box around About Garmin Express under Garmin Express
4. Click Check for Updates to Express
Red box around Check for Updates to Express
5. Click Install Now if prompted
Red box around Install Now
The latest version of Garmin Express can also be downloaded and installed from the Garmin Express page.
Garmin Express will be up to date once the installation completes.
If your Device has Already Been Added to Garmin Express, Try Removing the Device and Adding it Back Again:
To Remove the Device:
2. Hold Control (Ctrl) on your keyboard, and click the device when using a one-button mouse on a Mac
Remove from Express window on a MAC
3. Click Remove from Express
4. Click Remove
The device will now be removed from Garmin Express
To Re-Add the Device:
2. Connect the USB flash drive to the computer
3. Click Add Device
Add device screen in Garmin Express
4. Click Add Device when the device is found
Device found screen in Garmin Express
5. Follow the on-screen prompts to add the device to Garmin Express
Uninstall and Reinstall Garmin Express:
See Full Uninstall of Garmin Express
The latest version can be re-downloaded by visiting https://www.garmin.com/express once Garmin Express has been uninstalled.
If These Steps Did Not Resolve the Issue
Visit Related Content at the bottom of this page or the Garmin Express section of Support Center and you will find the available Product Support contact options in the Contact Us for More Help section.
Sumber terkait
