ICAO PBN/RNAV-RNP Codes
The tables below describe entries that are made in Field 18 (Other Information) on the ICAO format FAA Flight Plan (FAA Form 7233-4).
NOTE: Reference your navigator and transponder's Aircraft Flight Manual Supplement (AFMS) for details on which codes apply to your avionics.
For integrated flight decks, consult your OEM.
Field 18 Other Information
ICAO PBN/RNAV-RNP (part of Field 18) Operators should file their maximum capabilities in order to qualify for the most advanced procedures. Select a maximum of eight entries to follow PBN/
Capability
PBN/Code
Notes
OCEANIC/REMOTE CONTINENTAL PHASE
RNAV 10 (RNP 10)
A1
Area Navigation (RNAV). RNAV 10 supports lateral and longitudinal separation minima in oceanic and remote continental airspace.
RNAV 10 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 10 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNP 4
L1
Required Navigation Performance (RNP). RNP 4 is associated with operations in oceanic and remote continental airspace.
RNP 4 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 4 nautical miles.  This accuracy must be achieved by at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting.
ENROUTE PHASE
RNAV 5 All Sensors
B1
Area Navigation (RNAV) using all available sensors.
RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles.  This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNAV 5 GNSS (GPS)
B2
Area Navigation using the Global Navigation Satellite System (GNSS).
RNAV 5 DME/DME
B3
Area Navigation (RNAV) using Distance Measuring Equipment (DME). Able to calculate position w/in 5 NM radius at least 95% of the time.
RNAV 5 VOR/DME
B4
Area Navigation (RNAV) using VHF Omni-directional Range (VOR) and Distance Measuring Equipment (DME).
RNAV 5 INS or IRS
B5
Area Navigation (RNAV) using Internal Navigation System (INS) or Inertial Reference System (IRS).
RNAV 5 LORANC
B6
Area Navigation (RNAV) using LOng RAnge Navigation (LORAN) C.
RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles.  This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure .
EN ROUTE & TERMINAL PHASES
RNAV 2 All Sensors
C1
RNAV 2 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 2 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNAV 2 GNSS (GPS)
C2
Area Navigation (RNAV) using Global Navigation Satellite System (GNSS).
RNAV 2 DME/DME
C3
RNAV 2 DME/DME/IRU
C4
Area Navigation (RNAV) using Distance Measuring Equipment (DME) and Inertial Reference Unit (IRU).
RNAV 1 All Sensors
D1
Area Navigation (RNAV) using all permitted sensors.
RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNAV 1 GNSS (GPS)
D2
RNAV 1 DME/DME
D3
RNAV 1 DME/DME/IRU
D4
TERMINAL PHASE
RNP 1 All Sensors
O1
Required Navigation Performance (RNP) using all permitted sensors.
RNP 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNP 1 GNSS (GPS)
02
Required Navigation Performance (RNP)  using Global Navigation Satellite System (GNSS).
RNP 1 DME/DME
03
Required Navigation Performance (RNP) using Distance Measuring Equipment (DME.
RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle whit a radius of one nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
RNP 1 DME/DME/IRU
04
Required Navigation Performance (RNP) using Distance Measuring Equipment (DME) and Inertial Reference Unit (IRU)
RNP 1 means the aircraft navigation system must be abel to calculate its position to within a circle with a radius of 1 nautical mile.  This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure.
APPROACH PHASE
RNP Approach
S1
Required Navigation Performance (RNP) Approach (APCH).
GNSS (GPS) is the primary navigation system to support RNP APCH procedures.
Characteristics of RNP APCH:
- Straight segments , fly-by turns
-Allows for two-dimensional (2-D) non-precision approach (NPA)
-Allows for three-dimensional (3-D) approaches with vertical guidance
RNP Approach with Baro VNAV
S2
Required Navigation Performance (RNP) Approach (APCH) with Barometric Vertical Navigation (Baro-VNAV)
Characeristics of RNP APCH:
- Straight segments, fly-by turns
- Allows for two - dimensional (2-D) non-precision approach (NPA)
- Allows for three-dimensional (3-D) approaches with vertical guidance through useof barometri, vertical navigation (baro-VNAV)
RNP Approach with Radius to Fix (authorization required)
T1
Required Navigation Performance (RNP) Approach (APCH) with Radius to Fix (RF) - Special Authroization Required.
Like RNP APCH, GNSS (GPS) provides the primary infrastructure.
It allows reduced lateral & vertical obstacle clearnace, curved paths, and precise missed approach guidance.
RNP Approach without Radius to Fix (authorization required)
T2
Required Navigation Performance (RNP) Approach (APCH) without Radius to Fix (RF) - Special Authroization Required.
- Allows for two-dimensional (2-D) non-precision approahc (NPA)
- Allows for three - dimensional (3-D) approaches with vertical guidance.
FIELD 18 OTHER INFORMATION (Only commonly used code prefixes are shown below)
Information Type
Indicator
Notes
Equipment
PBN/
RNAV and RNP equipment codes to indicate capabilities. See ICAO PBN/RNAV-RNP table.
Navigation
NAV/
NAV/SBAS is entered to indicate WAAS capability and the ability to fly LPV approaches.
Communications
COM/
Communications capabilities not already specified in COM/NAV field.
Data
DAT/
Data capabilities not already specified in COM/NAV field.
Surveillance
SUR/
SUR/260B indicates ABS-B 1090 Mhz. SUR/282B indicates UAT capability.
Registration
REG/
Enter REG/##### if operating in RVSM airspace. Otherwise, enter registration markings if different from that specified in Identifier field.
SELCAL
SEL/
SELCAL code assigned to the aircraft.
Type of Aircraft
TYP/
Used if not specified in the Type field.
Mode S Code
CODE/
This is the aircraft Mode S code [base 16 / hex] obtained from the FAA Aircraft Registration database.
Status
STS/
Reason for special handling. See AFM (page 5-1-24) for list of codes.
Departure Airport
DEP/
When departing an airport with no ICAO code, enter ZZZZ for Departure Aerodrome and DEP/CODE (e.g. 2S7) in Field 18.
Destination
DEST/
When the destination is an airport with no ICAO code, enter ZZZZ for Destination Aerodrome and DEST/CODE (e.g. 2S7) in Field 18.
Alternate Airport
ALTN/
When the alternate airport is an airport with no ICAO code, enter ZZZZ for ALTN Aerodrome and ALTN/CODE (e.g. 2S7) in Field 18.
NOTE: For a complete description of Flight Plan filing codes, including entries possible for Field 18, refer to the FAA Flight Planning Information Web site.
Sumber terkait
