Managing Contacts in Garmin Connect
You can easily add, edit, or delete personal contacts within the Garmin Connect™ app.
Accessing Your Contacts:
  1. Open the Garmin Connect App.
  2. Select More (bottom right).
  3. Select Contacts.
Adding New Contacts:
  • To Create a New Connect Contact:
    1. Select Create a Connect Contact.
    2. Enter the contact details.
    3. Select Save.
  • To Import a Contact from Your Phone:
    1. Select the Phone tab.
    2. Choose the contact you wish to add to your Connect contact list.
Editing or Deleting Existing Contacts:
NOTE: Deleting a contact removes it from the features requiring the contact such as Incident Detection, Live Event Sharing, and Assistance.
  1. Under the Connect tab, select the contact you want to modify.
  2. Select Edit.
    • To Edit: Make the desired changes and then select Save.
    • To Delete: Select Delete Contact and confirm your choice.
Sumber terkait
