Running Power on the Venu 3 and Venu 3S
Venu® 3 and Venu® 3S smartwatches running the latest software will offer wrist based running power.
Enabling and Disabling Running Power
You can turn running power on or off anytime on your watch within the Run profile settings.
  1. Select the top button.
  2. Select Run.
  3. Swipe up from the bottom to open the menu.
  4. Select Settings.
  5. Select Running Power.
  6. Select Status to toggle on or off.
Data Fields
The Venu 3 will come with three power data fields, and a Running Power data screen that can all be adjusted on the watch.
To Enable the Data Fields:
  2. Select Run.
  4. Select Settings.
  5. Select Data Screens.
  6. Select the desired screen.
  7. Select Edit Data Fields.
  8. Select the desired field.
  9. Select Power Fields.
  10. Select Power, Avg. Power, or Lap Power.
To Enable the Running Power Data Screen:
  2. Select Run.
  4. Select Settings.
  6. Toggle the switch on the right to turn on or off.
The fields in the Running Power data screen can be customized.
Frequently Asked Questions About Running Power
