inReach Messenger Plus Menu Options
The home page and main menu on the inReach® Messenger Plus satellite communicator contain information that can be used to operate your device. From the home page, you can press Left Arrow Button or Right Arrow Button to scroll through the main menu options, and you can press OK to access more settings and information for each option.
The information below explains what settings and options are available for the home page and each of the main menu options.
Home Page
This page will display ACTIVATION Triangle With Exclamation Point if you skipped activation during the initial setup.
Once activated, this page displays the date, time, and status icons. It also displays tracking and weather information when those features are in use.
inReach Messenger Plus Home Page
Press OK to open the home page actions:
Check-In
Allows you to send a check-in message. For more details, see - Sending and Checking Messages on the inReach Messenger Plus.
Start/Stop Tracking
Allows you to transmit track points over the Iridium® satellite network so others can follow along while the tracking is in progress. For more details, see - Getting Started With Tracking on the inReach Messenger Series.
Message Check
Allows you to manually check for new messages. For more details, see - Checking for Messages.
View Coordinates
Allows you to view your GPS coordinates.
Back
Allows you to return to the home page.
Back to Top
Messages
inReach Messenger Plus Messages Page
Press OK to view your message history, send a new message, or reply to a message. For more details, see - Writing a Message on the inReach Messenger Plus.
Back to Top
Tracking
inReach Messenger Plus Tracking Page
Press OK to start and stop tracking or view the progress of ongoing tracking. For more details, see- Getting Started With Tracking on the inReach Messenger Series.
Back to Top
Check-In
inReach Messenger Plus CheckIn Page
Press OK to choose and send one of the following Check-In messages:
  • I'm checking in. Everything is okay.
  • I'm starting my trip.
  • I'm ending my trip.
Check-in contacts can be edited in the Garmin Messenger app. For steps, see - Editing Check-In Contacts in the Garmin Messenger App.
Back to Top
Weather
inReach Messenger Plus Weather Page
Press OK to view the last weather forecast or request an updated weather forecast. For more details, see - Requesting Weather Forecasts With an inReach Messenger Plus.
Back to Top
TracBack
inReach Messenger Plus TracBack Page
Press OK to start using TracBack. This feature can be used to retrace your steps even if tracking was not started at the beginning of a trip. For more details, see - Using TracBack on the inReach Messenger Plus.
Back to Top
Message Check
inReach Messenger Plus Message Check Page
Press OK to display when the last mail check was done and force a check for messages. For more details, see - How Often Does the inReach Messenger Plus Check For Messages?.
Back to Top
Test Service
inReach Messenger Plus Test Service Page
Press OK to test for active service by sending a test message. When you receive a confirmation message on the device, your device is ready to use.
Back to Top
Service Plan
inReach Messenger Plus Service Plan Page
Press OK to view data use.
Back to Top
Settings
inReach Messenger Plus Settings Page
Press OK to access additional settings to customize the device. Select "Complete List of Settings Options" below to see all of the settings options and their sub-menus. For more details on what each of these settings and options are used for, refer to your owner's manual.
inReach Messenger Settings
Settings MenuSub-Menu 1Sub-Menu 2Sub-Menu 3
Tracking →Send Interval →
  • 2 Minutes (Premium/Unlimited Plans Only)
  • 5 Minutes (Premium/Unlimited Plans Only)
  • 10 Minutes
  • 20 Minutes
  • 30 Minutes
  • 1 Hour
  • 2 Hours
  • 4 Hours
Auto Track (On/Off)
← Back
Sounds →Mute All (On/Off)
Volume →
  • Low
  • Medium
  • High
Message Rec. →
  • Off
  • Ascending
  • Descending
  • Start
  • Stop
  • Alert
  • Climb
  • Slide
  • Beep
  • Plunge
  • Chime
  • Chirp
  • Ring
  • Victory
  • Signal
  • Trio
Message Sent →
Critical Alert →
Power Off →
Ring Until Read (On/Off)
← Back
Phone →Bluetooth Status (On/Off)
Status (Connected or Waiting for Phone)
Pair Phone
← Back
inReach Remote →Status (On/Off)
Device Number
Verified Devices
← Back
System →Backlight →Brightness →
  • 0%
  • 10%
  • 25%
  • 50%
  • 75%
  • 100%
Timeout →
  • 15 Seconds
  • 30 Seconds
  • 1 Minute
  • 2 Minutes
  • 5 Minutes
  • Always On
← Back
Language →(select a language)
Compass Cal. →(Follow prompt to rotate device in a figure 8 motion)
Time →Time Format →
  • 12 Hour
  • 24 Hour
Time Zone →
(Automatic or choose a time zone from the list)
Daylight Saving →
(This option will not appear if Time Zone is set to Automatic)
  • On
  • Off
  • Automatic
← Back
Units →Position Format →
(Choose a format, datum, and spheroid setting; for more details, see - Position Formats Supported by Garmin Outdoor Devices)
Speed/Distance →
  • Statute Miles
  • Kilometers
  • Nautical (nm, ft.)
  • Nautical (nm, m)
Wind Speed →
  • mph
  • kph
  • kt
  • m/s
Temperature →
  • Fahrenheit
  • Celsius
Bearing →
  • True
  • Magnetic
← Back
Auto Download Photo & Voice Messages (On/Off)
Messaging Mode →
  • Performance
  • Low Power
Reverse Charging →Status (On/Off)
Charging Mode →
  • Charge Only
  • Charge and Send
← Back
GPS →
  • GPS Only
  • Multi-GNSS
USB Mode →
  • Prompted
  • Automatic
External PowerAuto Off (On/Off)
Reset →Reset Default Settings
Delete All Messages
Delete Data and Reset Settings
← Back
Software Update →Check For Updates
← Back
About →Unit ID
Address
IMEI
Auth. Code
Firmware Ver.
Regulatory
License
← Back
← Back
Back to Top
