Navionics Boating: Determining Distance Travelled
There are two ways to determine distance travelled in the Navionics® Boating app.
The first way is to simply measure the distance from one point to another using the distance tool in the lower right corner of your map screen. That will give the distance on a straight line between the two points.
The second method is to start and record a track from the start to the end point. That will give a distance along the track travelled rather than a straight line.
